08 848 stator to 907
Posted: Fri Sep 09, 2016 1:15 am
by MG907
Does anyone know if a 08 848 stator will work on a 91 907ie?
Thank You
Re: 08 848 stator to 907
Posted: Fri Sep 09, 2016 9:20 am
by Derek
It can't be fitted. The 907 is single phase with the rotor turning inside the stator. The 848 is 3-phase and the rotor turns around the outside of the stator. The crank is different to take later rotor which is part of the flywheel assembly and the outer casing is different to house the 3-phase stator. There are so many changes that you'd need to swap the entire lower half of the engine - crank, crankcases, alternator cover and probably an awful lot more, if it could be done at all.
