It is currently Mon Jan 21, 2019 5:26 am
 Post subject: Adding engine oil
PostPosted: Mon Feb 19, 2018 6:23 pm
Well, this may be the dumbest question asked here in awhile, but which part of the right side fairing do you remove to add engine oil? I tried removing the rear part, but it's secured in the middle of the panel somehow and I could figure out how to get it loose. I'm a non-mechanic :cry: and am wary of breaking a fairing tab or something, so any advice would be welcome! Thanks!!
 Post subject: Re: Adding engine oil
PostPosted: Mon Feb 19, 2018 6:40 pm
To remove the rear side panel remove the seat and then the two bolts holding the panel to the large front side panel. Then pull the front of the rear panel carefully outwards. There are two plugs on its inner side that sit in rubber grommets on the bottom side of the tank which is why it's still holding when the two bolts are removed. See pic below.
After that pull the rear panel forward and it will come off.
On the taillight there are two pins the side panel is stuck on to. If you pull it too far outwards in the front it will crack in the rear so be gentle.
PostPosted: Mon Feb 19, 2018 7:06 pm
While G is correct ( above ) he left out the best bit :D . Technological advances born of Kiwi cunning ......and an almost total lack of funding have led us to this revelation
which might keep greenpeace of your back :lol:
PostPosted: Mon Feb 19, 2018 7:10 pm
THANKS!!!
PostPosted: Tue Feb 20, 2018 3:11 am
Always impressed by your shop tools McT. mine has a piece of green garden hose... i'll have to upgrade to the black :-).
PostPosted: Tue Feb 20, 2018 3:13 am
Anyone got any spare of these grommets? My bike lost them before getting to me and i have a work around in place. if i had a proper one i could make a copy of it...
P-)
PostPosted: Tue Feb 20, 2018 8:37 am
Stein Dinse still lists them (https://www.stein-dinse.biz/Complete-pa ... anguage=en) so you should be able to order them via your Ducati dealer as well.
PostPosted: Tue Feb 20, 2018 1:04 pm
P-)
They are still available through your local Ducati dealer. I purchased a few about 2 years ago, but couldn't work out why the 907 I had didn't need them? Then I took a close look at the side panels and saw the very fine hacksaw marks where a previous owner had cut the knobs off!?
Oh well...
Cheers.
Nick.
PostPosted: Tue Feb 20, 2018 9:44 pm
Mmmm, John Bobbit
PostPosted: Wed Feb 21, 2018 9:26 am
nickta wrote:
P-)
Oh well...
Cheers.
Nick.
Strange. The RH panel from my 907 has knobs on it but the LH panel doesn't although I can't think why anybody would remove them. I bought a pack of grommets for a Honda 125 off ebay which were the right size.
1982 Pantah 500SL
PostPosted: Wed Feb 21, 2018 11:15 pm
https://www.ebay.co.uk/p/71-78-Honda-Cb ... 0005.m1851
BMW K100RS PATINA CAFE RACER
