It is currently Thu Jan 23, 2020 6:19 pm
 Post subject: Starter solenoid mod
PostPosted: Wed Mar 28, 2018 6:14 pm
I was getting fed up with the poor connection to the starter solenoid on my 907ie. These are the old style solenoid with the plug in connector that has a habit of falling out. Even with a cable tie round it doesn't always make a connection. The trouble is that the round socket terminals get enlarged and just don't grip the pins in the solenoid properly.
I wanted to fix this once and for all by replacing the solenoid with a spare 1098 one that I have and replace the loom connector with one that matches the inline connector on the solenoid but was unable to find a source for the connector anywhere.
However, since the original solenoid itself was ok but it's connector was source of the problem, I decided to modify it. I soldered wires directly to the pins in the connector and fitted an AMP Superseal connector to the other end, fitting the matching connector to the loom. It's working great now. The white goop is silicon I used to seal the soldered joints.
1982 Pantah 500SL
 Post subject: Re: Starter solenoid mod
PostPosted: Wed Mar 28, 2018 10:01 pm
Ha Ha just done exact same thing with my re wire although I am in no position to test it as have half the loom still stripped.
BMW K100RS PATINA CAFE RACER
PostPosted: Thu Mar 29, 2018 8:13 am
Great minds ... ;)
1982 Pantah 500SL
PostPosted: Mon Apr 02, 2018 4:00 am
I pushed mine down Queen st for about 2 blocks ( :mad: hot day , gathering audience ) before thinkin' of lookin under the seat :idea: . Paso would have to be the most bastardy bike to try and crash start as you cant really jump on board ( side saddle )when you get the plot rolling
