It is currently Mon Jun 24, 2019 8:59 am
 Post subject: Mystery item! Found this in my oil!
PostPosted: Sun Jul 15, 2018 2:43 am
Changing the oil in my 907ie and this came out in the old oil. Made of lightweight alloy, I think. Anyone know what it used to be?
 Post subject: Re: Mystery item! Found this in my oil!
PostPosted: Sun Jul 15, 2018 8:21 am
No idea I'm afraid but I wouldn't like to find it in my engine!
1982 Pantah 500SL
PostPosted: Sun Jul 15, 2018 11:14 am
I’ve never been into a Ducati transmission but that looks like a baulk ring/syncromesh?
PostPosted: Mon Jul 16, 2018 5:16 am
Hi All,
To me it would appears to be a fragment from a bearing cage...
Cages can fail at times and are typically supplied in a host of materials, ranging from brass, nylon, etc etc, right through to cotton/phenol resin.
Just note if it does turn out to be part of a cage, chances are you will continue to come across more fragments, and in time the bearing will likely collapse...
Regards,
Marc
PostPosted: Mon Jul 16, 2018 8:48 am
After having another look at it I think you are right.
1982 Pantah 500SL
PostPosted: Mon Jul 16, 2018 9:12 am
Thank you for those replies. The bearing cage or retainer seems to be the best answer. What bearings are in there and how difficult is it going to be to get in and replace them?
PostPosted: Mon Jul 16, 2018 10:50 am
Crank, clutch, gear output etc bearings. SKF are cheaper.
You have to separate engine blocks.
Shimming crank etc not too difficult.
Primary gear a real PITA to remove, real sturdy puller
and great care needed, it could fly off w force!
PostPosted: Mon Jul 16, 2018 2:14 pm
So looks like one of these bearing cages then to help visualise...
https://www.ebay.ie/itm/Ducati-749-Supe ... 2117508256
PostPosted: Thu Jul 19, 2018 9:12 am
Indeed it does look somehow familiar and like a crankshaft bearing cage but it can't be if it really is lightweight alloy (or is it actually magnetic?).
Whatever it is I'm wondering where the rest of it is. :huh:
PostPosted: Sat Jul 21, 2018 9:39 pm
Huh , looks like a Canadian quarter to me :D
PostPosted: Wed Sep 19, 2018 12:44 pm
Part of crankshaft bearing also for me.
Gabriel
Paso 750
Elefant 750 Monofaro
Elefant 900 Monobraccio
Elefant 750 pure off
Indiana 650
PostPosted: Wed Sep 19, 2018 10:18 pm
Have a look around your sprocket area to see if you have had any welding done from/after a snapped chain as you never know it may of been stitch welded from the outside and this may be a small fragment from the inside of the casing? Both my engines have been welded previously and I didn't realise it until I had cleaned all the crud away.
BMW K100RS PATINA CAFE RACER
