The 1991 907ie on my bench right now has no spark, and has arrived as a 'none of the shops around town could fix it' kind of thing. My hope is that the ECU and MAEs (#39 power module on schematic) are good, and I will hopefully get some oscilloscope traces this weekend, but am having trouble figuring out some of the signal behavior.
Doing some digging on forum I've found a lot of good info (many thanks to the community)
https://app.box.com/s/3elasen7q7
http://sonic.net/~mikebr/efi/ecu_hdwr.html
The 'known goods' found thus far, having spent some time with a multimeter, are:
1. The fuel pump runs for a few seconds when the key is turned on, then shuts off as expected.
2. Both fused relays toggle (and fuses do not blow) when the key/kill switch engage.
3. The engine cranks with the start switch (switch, solenoid and motor seem OK)
4. The MAE is receiving 12 VDC, and the GND is connected.
5. The coil is receiving 12 VDC, and the GND is connected.
When cranking with the start switch, neither spark plug produces a visible spark.
A spark can be observed on both cylinders at the moment the key is turned off (weird) which leads me to believe the coils are OK, I will OHM them when I get a chance based on the data found on this forum(many thanks).
Looking at the schematic I couldn't tell if the BlueRed(Pin 24) wire common to both MAE plugs was supposed to be a digital common, or some kind of enable/disable voltage? (like the kill switch SCR gate on a CDI)
Pin 24 on the ECU is resting at 0volts with the MAE plugged in with the key on. It bumps to ~0.1 volts (still zero) when the starter is running. Pin 24 floats to 2.5VDC with both connectors removed.
I guess my question is:
Should the Pin 24/BlueRed pull up to 5VDC when the ECU wants the MAE to be able to spark? Or is that zero normal?
My plan is to oscilloscope the Blue wire and the Red wire on each MAE to see if they're getting any signal to spark from the ECU. Will post if I get any interesting pictures.
A few more questions:
Has anyone else had both sides of the Power Module fail?
Additionally, would a dead sensor (such as 33,34 on schematic) or some other ECU feedback signal cause it to intentionally kill spark?
Could a burned out EEPROM do something like this?
Sorry for the long post, just hoping to get her back on the road... thanks in advance for any feedback.
-Ian
1991 907ie No Spark! ... ECU, MAE tests?
1991 907ie
1979 XS1100
2012 Street Triple R
-I'll fix anything, except your: pinball machine, hot tub, juke box....
1979 XS1100
- Derek
- year: 1994
Re: 1991 907ie No Spark! ... ECU, MAE tests?
It is unlikely for both MAEs to fail simultaneously so the problem more likely lies with the ECU. Have you made sure that the crank and cam sensors are plugged in the right way round. If they get swapped you will get no spark. If either of them have failed you will not get a spark either. If the fuel pump runs while the engine is turning the timing sensors are likely to be ok.
Have you checked the Pickup? I would start from there; make sure it works and just in case check the distance from the flywheel "hump" is 0.6- 0.8mm
I wonder if they touched the flywheel or the pickup...
The P7 was fitted to many cars so a Marelli Specialist could check it on the bench to see if it is working.
It could well be also that the eprom got corrupted , one option is to find a working 907 near you go there with your ECU and test it on the other bike, this way you can see if it is the ECU without risking of damaging a "borrowed one " by fitting it to a potentially faulty wiring.
The other thing is the wiring, check all connectors, clean then and lube them with grease, just in case some oxidation is cutting the connections and of course the grounds.
- englishstiv
really silly thing but so simple a fix if its this?
Check the small wire that clips into the solenoid.
Derek has already shown a fix for this and I have already done likewise, if this drops off or is damaged you wont get a spark.
http://ducatipaso.org/forum/viewtopic.php?f=3&t=7892
Check the fuses also as this can also have a detrimental effect also.
Has you bike had any re wiring done as you can also do a mod to boost the spark - has this mod failed?
Check all your wiring also as with my bike a lot of the connectors have failed through age with wires loose and in some areas actually pulled out of the pins.
DUCATI 907ie 1992
Thanks for all the responses.
I was able to get some time in with the 907ie over the weekend.
Right off, the fuel pump relay was turning on when the starter was turning. Which I suppose indicates the timing sensors are OK. The sensor pins at the computer showed some voltage wiggle on both sensors (though not sure if it's the correct wiggle) ... sadly the pictures didn't turn out, but at least they're connected well enough and doing something.
The pins to the MAEs are stuck at zero volts when cranking, so the ECU, for some reason, is not putting out the signal to fire. With the computer removed, and the two relays toggled by hand, I injected a 16Hz 5v square wave into the MAEs, (pin 24 digital GND, 25 and 26 as 5v signal to fire)and got healthy spark out of each spark plug. (this eliminates both MAE and wiring to harness as a problem)
The ECU is at least not totally fried. There are no burn marks or indications of excessive heat. The pin 10 signal to toggle the relays is working. The bike does have ~50k on it, so maybe the EPROM is burned out?
So I guess it's time to shop for an ECU? Maybe start with just the EPROM?
Thanks all,
-Ian
Thanks all,
-Ian
1991 907ie
1979 XS1100
1979 XS1100
- Derek
- year: 1994
No. It shows that the fuel pump relay is ok and that the ECU is switching it on and off at switch on, which it should do.Foc_ian wrote: Right off, the fuel pump relay was turning on when the starter was turning. Which I suppose indicates the timing sensors are OK.
The ECU depends on a signal from the timing sensors to turn on the relay while the engine is turning, either under starter power or under its own steam.
As long the ECU gets the signals from the timing sensors it keep relay switched on and uses the signals from them to create the spark and injection pulses and drive the revcounter.
On the P7 ECU both sensors must be operative. If the crank (M) sensor and the cam (C) sensor are swapped round i.e. M plugged into C loom connector and C plugged into M loom connector there will be no spark either.
The pickups are inductive and should have a resistance of around 680Ω ±10%. They should create a pulse if you wave close to the pickup head.
Spent some time with the 907ie over the holiday.
Tried putting a used ECU on (ECU was from another 907ie and had a 907ie EPROM already) which didn't solve the issue. No smoke came out of the second computer.
I tried to check the outputs from the ECU to the injectors, and didn't see any signal. This may support the theory that the computer is not firing on purpose.
I got some somewhat visible scope shots of the waveforms coming off of the tach and timing sensors. I hope they are attached. They were taken with no load.
It appears both sensors on the bike are the same part. They ohmed the same. I checked that the timing and tach sensors were plugged into the right pins on the ECU. The timing sensor was ~5X greater in magnitude than the tacho. Both were adjusted for the shortest pickup distance the adjustments would allow.
I tried swapping the pickups, and the low amplitude stayed with the tach position. If the low tach amplitude is the problem... Maybe the ECU kills ignition and fuel when it loses tach signal? Kinda weird. I could see the timing sensor doing that... but the tach? Also I don't really see how the steel on the rotor could de-mag, or the spacing could change (larger gap)... which is the only way that amplitude would drop.
Whatever is going on it's weird. Or the second ECU silently fried with no clear indication of having done so. Or was somehow bad in the same way.
The only thing I can think to do is throw timing and tach sensors at it. Which seems unlikely to fix the issue (sort of like the new/used ECU didn't..... )
- Tachometer Sensor Wave Form
- Tachometer Sensor.jpg (26.58 KiB) Viewed 11676 times
- Timing Sensor Wave Form
- Timing Sensor.jpg (17.68 KiB) Viewed 11676 times
1991 907ie
1979 XS1100
1979 XS1100
- Derek
- year: 1994
I'm fairly sure that the ECU needs the tach signal to fire as well as the timing signal. A further test on these is; does the fuel pump relay energise when the engine is cranking?
The sensors are inductive, like a guitar pick up. They have a magnet inside them with a coil wound round it. When a steel or iron object is moved near to it it creates a voltage while it's magnetic field is being disturbed. The mass of the metal object (teeth on the flywheel) might have some effect on the size of the pulses.
I can see no other reason why the sensors should give a lower output in the tacho position unless something is pulling it down. I would have thought possibly a failure in the ECU but swapping it made no difference. What about the wiring? Is there any corrosion or oxidation at the connectors or a contaminant allowing a leakage path to earth?
I was going through some old pictures and realized I never posted the solve for this one.
Turns out the tach sensor needed a spacer to increase the signal. the low amplitude trace was due to the sensor being too close. Someone had removed the sensor and failed to replace the spacer...
Hope this helps someone some day!
1991 907ie
1979 XS1100
1979 XS1100
- Derek
- year: 1994
Thanks for posting the solution.
