It is currently Sun Mar 07, 2021 2:33 am
[ 3 posts ] |
Author |
blakduc1
Post subject: Fuse Block Posted: Mon Sep 07, 2020 1:15 pm |
Joined: Tue Aug 25, 2020 8:37 pm Posts: 8 Location: USA
Anyone ever replace the fuse block on a 907? Mine is falling apart. Literally crumbling. Whatever the material is, it was not made to withstand the test of time.
Does anyone have a good aftermarket replacement for that item? I did order one for marine application, but it is a little large. It may work, and is high quality, but I think I will look for one closer to the original size.
_________________ 1992 907ie, (x2) Anthracite
Top |
Post subject: Re: Fuse Block Posted: Mon Sep 07, 2020 3:02 pm |
paso grand pooh-bah |
Joined: Tue Jul 29, 2008 9:50 pm Posts: 3233 Location: Hilltown,Pennsylvania
Eastern beaver has some good ones
Top |
Willo
Post subject: Re: Fuse Block Posted: Mon Sep 14, 2020 5:26 am |
Joined: Mon Dec 14, 2015 4:07 pm Posts: 11 Location: Australia
When mine fell apart I used a Narva 54420BL. I used insulated spade connectors and bent the terminals a bit for clearance.
Cheers Willo Wannon Victoria Australia
Attachments: |
_________________ Willo Wannon Victoria Australia 91 907ie 95 748
Top |
[ 3 posts ] |
Users browsing this forum: No registered users and 15 guests |
