It is currently Tue Oct 27, 2020 1:02 am
 Post subject: Cog gear
PostPosted: Wed Oct 14, 2020 12:59 am
I have replaced the sprag gear .bike started and ran ,for a little while ,then same problem again , would not start ,turns out cog gear is issue , removed and cleaned sanded with 1200 and replaced, now it will start , my question is how do I replace shaft that the cog gear is on ? , does it come out ? Any advice is welcome and greatly appreciated
 Post subject: Re: Cog gear
PostPosted: Wed Oct 14, 2020 10:17 am
I presume you mean the starter intermediate gear? As far as I know the shaft is an interference fit into the crankcase half although I can't find any reference to replacing it in any Ducati workshop manual. Short of dismantling the engine you should be able to use a length of tube and suitable washers with a screw into the shaft to pull it out. You'd be best to heat the crankcase it the area of the shaft with a heat gun before pulling it .
PostPosted: Wed Oct 14, 2020 10:58 am
on the spare parts catalogue the gear is held with a circlip and the gear pin is bolted to the crankcase trough a long allen bolt.
my guess is that the pin is fitted with a slight interferance, and the bolt does the holding.
PostPosted: Thu Oct 15, 2020 9:11 am
Ah. That makes sense and explains the length of the bolt.
PostPosted: Thu Oct 15, 2020 3:19 pm
Sprag has to be the most troublesome part of these engines. I keep a supply of new springs and end up replacing them every other year. I have replaced the idle gear and shaft when experimenting with readily available springs I ended up welding the idle to the shaft during this trail. Yes the shaft is removable.In the end I found a guy in England sells the proper spring. I have also tried other types of sprags with no luck so far. Recently a new updated spag has become available From a source in Italy and I have one to try as once again it is slipping
PostPosted: Fri Oct 16, 2020 6:23 am
Online
Hi Higgy , do you think the sprag failures maybe oil type related. When I was still riding my Paso ( been near 15 years now ) I did about 60k kms on it and never had a sprag problem , did make some awful noises if it backfired when starting tho . I used valvoline xld oil . Just thinkin :-)
PostPosted: Fri Oct 16, 2020 3:34 pm
I think it is heat that sacks the spring so yes oil would have its part to play. Dont know if the st type oil slinger would help
PostPosted: Fri Oct 16, 2020 8:58 pm
Online
I had a sprag "reverse" itself in an auto trans on my car (ZF 4hp22 ),pain in the arse as car wouldnt move off in drive , had to put it in L to move off then shift to D and then all was normal till next time I stopped .
