It is currently Wed Apr 14, 2021 10:43 am
 Post subject: Fork oil level
PostPosted: Fri Mar 19, 2021 9:19 am
Looking at changing the oil in my MIR forks, manual states 160mm for oil level. Is that measured from the top of the tube with the front wheel off the ground? And both forks the same? thanks.
 Post subject: Re: Fork oil level
PostPosted: Fri Mar 19, 2021 10:28 am
It is measured with the springs out and the forks fully compressed. The manual I have says 180mm ??
PostPosted: Sat Mar 20, 2021 12:02 am
sorry, my mistake, was posting from memory. thanks
PostPosted: Sun Apr 11, 2021 8:11 pm
what oil did you use? 5 or 10 wt?
