inlet manifolds dellorto and brake adaters
ir_joep
Post by ir_joep »
Searching the www for inlet manifolds for dellorto's, I was supprised to find so little and at high prices.
I know somebody how would be able to cast some for a reasonable price if their is enough interest. so please let me know who wants a set and who is willing to sent his/her set to be used as a template.
prices for mallossi are over 120 euro which i find too pricy
On the other hand it could be that I'm not looking at the right places for cheap manifolds so please direct me to those locations if you know of any.
The same applies for brake caliper adators to go from the original 2 piston setup to early 4 piston setup as you would find on F1 santamonica bikes. We will use the drawing as found on this website and of couse not use casing but machining in the correct specified aluminium.
Im ordering both manifolds and adapters anyway, but a batch run would be cheaper.
hope to hear from all of you, thanks !
Joep
