headlight ducati 750--900 sport.
I need a headlight for my 900 European, I have the one of my English motorcycle, not valid to drive in Europe.
If you are in England and have the same problem, I can make a change.
If you have a European one, for sale, on your shelf, I can also buy it.
- model: 900 SS
- year: 1989
Re: headlight ducati 750--900 sport.
Gday mate, if the English light is the same as Australian I could do a swap as I only have the European unit, if that would help, cheers
Just in case you do not succeed: a new one (CEV 287 288).
https://www.ebay.es/itm/FARO-ANTERIORE- ... 2855320827?
Good luck!
Good luck!
Please do check the CEV numbers on your headlight, to be sure it's the correct one.
Frank, that headlight for the later 900SS does not fit the 89/90 900SS which used the same one as the 750Sport and F1.
- model: 900 SS
- year: 1989
Anyone know the correct CEV numbers for the aussie headlight, cheers
Just have a look at the parts catalog
067038200 is for rhs traffic
067038210 for lhs
067038210 for lhs
If someone has a clear picture of the headlight with brand (CEV, Carrello etc.) and numbers or even the dimensions I can try to find out whether it was also used for other vehicles (Fiat?).
Production numbers were so low in the mid eighties, chanses are it was not a "Cagiva special".
If I could get the dimensions also it would be helpfull.
Just let me know if you want me to look for a source .....
I hardly know the 900ss but I've done this exercise a few times for my Bimota and some Cagivas a few years ago.
First items I search for/buy when I have a restoration project are all items related to lights and rubber parts.
Then I will go to my garage, I will try to photograph the two lighthouses.
I've tried it before, but the numbers are not clearly seen by the reflection of the crystal.
I'll try again.
I'll try again.
komme aus der Garage zurückFrank.61 wrote:If someone has a clear picture of the headlight with brand (CEV, Carrello etc.) and numbers or even the dimensions I can try to find out whether it was also used for other vehicles (Fiat?).
Dies sind die Anzahl der Scheinwerfer und die Maße.
Der Leuchtturm rechts und der Leuchtturm links.
Es wäre für alle gut, zu wissen, ob ein anderes Fahrzeug die gleichen Scheinwerfer hat.
Grüße
- hOMOLOGACIONES FARO EUROPEO.jpg (29.32 KiB) Viewed 8668 times
- Faro 2.jpg (128.16 KiB) Viewed 8668 times
- Faro 1.jpg (128.83 KiB) Viewed 8668 times
- hOMOLOGACIONES FARO INGLES.jpg (19.67 KiB) Viewed 8668 times
- Faro 4 (2).jpg (126.19 KiB) Viewed 8668 times
- Faro 4 (1).jpg (118.82 KiB) Viewed 8668 times
- Medidas faro.jpg (76.6 KiB) Viewed 8665 times
So that I understand it correctly: do you need a CEV 304 or a CEV 364?
The CEV 304 I see new ones on ebay, no 364 though ....
Danke FrankFrank.61 wrote:So that I understand it correctly: do you need a CEV 304 or a CEV 364?
I still have the English lighthouse, for the left.HIGHWAY89 wrote:Gday mate, if the English light is the same as Australian I could do a swap as I only have the European unit, if that would help, cheers
HIGHWAY 89, do you still need it?
You have a PM
