It is currently Tue May 26, 2020 7:31 am
 Post subject: adjustable cam pulleys currently on offer at Stein Dinse
PostPosted: Fri Nov 23, 2018 10:23 am
https://www.stein-dinse.biz/product_inf ... _id=438083
or as a set:
https://www.stein-dinse.biz/product_inf ... _id=438086
The compatibility list is incorrect tho. These will fit also the 907IE and 900SS, Cagiva Elefant 900 etc. (basically all pre testastretta engines with round tooth belts and 18 tooth pulleys).
The two pulley set will not work on the 750 Paso or Sport as these two have square tooth belts. One would have to get the 4 pulley set and replace the old belts with round toothed ones.
 Post subject: Re: adjustable cam pulleys currently on offer at Stein Dinse
PostPosted: Fri Nov 23, 2018 1:27 pm
All new Ducati have adjustable pulleys, it is worth checking the price at the dealer , often you get a pleasant surprise
PostPosted: Fri Nov 23, 2018 3:08 pm
agree, but which ones from a new bike fit on a Pantah engine?! To my knowledge most new cams have a different diameter.
I do think €95 for the pair is a really good price. If you find any they are usually over 150 (at least that was so in the past).
PostPosted: Fri Nov 23, 2018 3:51 pm
the diameter is irrelevant provided you replace ALL of them, which you need anyways so uyou can fit the new round tooth belts
this what I did to my old, very old Elefant750 engine (only the cases are from the Elefant, but that is just a little detail...), I ended fitting the ducati M620 pulleys.
PostPosted: Fri Nov 23, 2018 4:35 pm
I meant cam diameter not pulley diameter. Some pulleys just won't fit on the cams.
PostPosted: Fri Nov 23, 2018 5:02 pm
gotcha! :mrgreen: :mrgreen:
PostPosted: Tue Nov 27, 2018 6:58 pm
... and they are back to normal price. Imo still not bad since there's a seller in the UK selling the pair for GBP170.
