It is currently Sat Feb 29, 2020 3:45 am
 Post subject: 906 Paso headlight UK spec wanted
PostPosted: Thu Mar 28, 2019 10:20 pm
Evening Chaps and Chapess'
My first post on here.
I am looking for a UK spec headlight for a 906 Paso.
I can offer a swap for a Euro spec one if that helps?
Kieran
 Post subject: Re: 906 Paso headlight UK spec wanted
PostPosted: Fri Mar 29, 2019 8:24 am
Kieran,
you can fit the Koito unit of a Yamaha FZ750. It's a direct replacement and you'll have no problems finding one.
PostPosted: Fri Mar 29, 2019 9:20 am
What G says : https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=Yamaha+FZ750+headlight&_sacat=0
Unfortunately most available are RH dip and some of these old lamps are quite fogged though so try to find a good one. I had to find one for my 907 which came with a European headlight, almost certainly from new.
1982 Pantah 500SL
PostPosted: Fri Mar 29, 2019 12:58 pm
Thanks.
I did see the FZ 750 lamp as a possible replacement. However most of the ones on there appear to be 1 digit out from the recommended 1985-86 lamp.
Can anyone tell me the difference between the 85-86 lamp and the 87-89 one?
The 85-86 one has a number of 110-31420 and there are a few on there of the later spec showing 110-31421.
Kieran
PostPosted: Sat Mar 30, 2019 2:34 pm
the 110-31420 is the dual headlight
https://www.amazon.co.jp/%E3%83%A4%E3%8 ... B00YIG0FVQ
the 110-31421 is the single headlight
PostPosted: Sat Mar 30, 2019 6:53 pm
Thanks for the info. Done a deal and hopefully the item that turns up is in good condition.
