I'm located in the US and I need a 907ie swingarm. Let me know if you're willing to part with one or know where I can get one
Thank you
WTB 907 swing arm
Re: WTB 907 swing arm
Pretty sure Monster 900 1994-03
and 851/888 is the same.
definitely not. Those don't have the swingarm linkage.
If the swingarm is damaged, it can be welded.
Think I still have an extra
In short, the chain wore thru the swing arm and it looks like it's just at the cage of the bearings. If I knew a good welder here, I would attempt to see if it could be saved.
Now I know why the previous owner cleaned everything off but the crud on the swing arm. Lol. This bike is definitely a learning experience too. I'm really starting to get higgys post.
I did buy one off ebay but the seller had to refund my payment because he didnt realize he no longer had it. I think I found another one but I'm not going to believe until it's in my hands.
Ooops, had a brain fart.
Gerhard is right.
Gerhard is right.
Into the cage for sure
- 20200710_205616.jpg (306.31 KiB) Viewed 4203 times
Thats what happens when the chain is to loose, but that aint the worst Ive seen . I would not panic about that to much , make sure the chain is properly tensioned and fit a new chain slider ( snigger)to the swingarm and try not to think about it .
H
H
