907ie parts interchangeability cam shaft
raicerx
Post by raicerx »
I have a 907ie 1993 and need to change the front cylinder cam shaft, are there other motors that use the same shaft? finding a spare 907ie part is hard.
Ducman
Post by Ducman »
Ducman
Post by Ducman »
Ducman
Post by Ducman »
raicerx
Post by raicerx »
thanks they only show stage 3 and i am riding street. i will call and see if they have something else.
Ducman
Post by Ducman »
when I looked at FBF they had race and street grinds, you should see if your cam can be reground as these guys aren't exactly cheap
raicerx
Post by raicerx »
my pulley gear and my shaft are warn where the woodruf key goes I am going to replace the gear with an adustable one by veetwo and cut a new groove in the shaft on the opposite side. That should work right?
