Rear shock adjuster
- streetsurfer
Rear shock adjuster
Are parts available for the rear shock compression adjuster? Fiddling around in the garage the other day, I backed off the adjuster about a half turn and I heard a 1/4 second or so of gas escape...phssst!. Is it likely to need a rebuild now? I don't recall it ever releasing air during adjustment.
- Finnpaso
- year: 0
Öhlins? Marzhocci? At leat to Öhlins You can get still easily rebuilt kit, but have to use Öhlins maintain then. Also to 907 Marzocchi U can get still rebuilt kit, but i think, that to 750 Marzhocci U cant get that anymore, if such have been earlier... 750 Marzhocci unit is different, as they use in 907IE. Remembering, that they use same in 906, as 750. But 907 have that "Duo shock" unit.
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
