It is currently Sun Feb 25, 2018 7:40 pm
Post new topic Reply to topic  [ 125 posts ]  Go to page 1, 2, 3, 4, 5 ... 9  Next
 Post subject: Manuals, magazine articles and other downloads
PostPosted: Sun Jan 07, 2007 3:08 pm
Hi everyone,
most of the files below can be found also in the document section of the main site.
I`ve uploaded the files on an external hoster, too just in case the site should crash and files get lost as it already happened in the past.
I don`t know if the place I`ve uploaded the files has a traffic limitations, if so pls retry another time.
Also if the pages don`t show in your browser hit the refresh button.
If you own magazine articles, brochures etc and have the possibility to scan them let me know via pm.
Brochures and magazine articles:
brochures
Magazine articles and reviews
dutch
english
french
german
italian
spanish
General:
Ducati Paso buyer`s guide
https://app.box.com/s/2fhq2uukm6t3hc14mboele7zupkdgq2e
Ducati Belt-Drive Two-Valve Twins - Restoration and Modification
(Paso/Sport part & appendix - production numbers/ technical specs - only)
http://www.box.net/shared/nzfez3vs4q
Haynes manual SS/Monster (for Paso/Sport relevant parts only)
https://www.box.com/s/dcym4984vznkj8tpacp6
Overview of clutch discs packs & disc order from SURFLEX
https://app.box.com/s/w2y6okcblz8ve8xtxr45
https://app.box.com/s/0jou7koxsuy3fd8vwhcmratvm8w0m3yo
engine doesn`t start - fault finding chart (doesn`t cover specific 907i.e. issues)
https://app.box.com/s/x8fmn1brzuya97x8z44z
Service bulletin regarding gear selector mechanism - all Ducati models
https://app.box.com/s/ccqi4o1hoelpn458dffawwf51kiq20cs
Carburation:
Weber manuals
http://www.box.net/shared/adnox7gm4n
Mikuni manuals
https://www.box.com/s/gslivfnzo4d3ak79cqs1
Dellorto manuals
https://www.box.com/s/tpt2q4mfepejq6ab91wx
Keihin FCR carb infos/manuals
https://www.box.com/s/sbjnzj00pvd4mmemr0cf
Ignition:
Adjusting ignition timing (cam dialling)
https://www.box.com/s/ihqtb1fw1jmt9xo55jbw
timing disc:
http://www.bevelheaven.com/downloads/Un ... ngDisc.bmp
diy TDC finder
https://www.box.com/s/tysuio186n95lhlj1pdu
Electrics:
charging system (stator & regulator/rectifier) fault finding chart from ELECTREX/ElectroSport
https://www.box.com/s/l97psjbqeswn9dk403ki
https://www.box.com/s/jzxzqy9x27xkeu4w2kdc
ElectroSport ESR515 and Electrex RR51 installation
https://app.box.com/s/r16ixjegwfl7aq3ybd0c
Diode testing guide from ElectroSport
https://www.box.com/s/92vrafnr2ajarh65j2pf
Shin Yo regulator installation
https://app.box.com/s/y5n81gem88ul3ymp6a0v
Repairing the ignition switch
http://www.box.net/shared/4evp1px5be
Repairing the starter solenoid (shown on a Pantah engine)
http://www.box.net/shared/njqjcaortr
Repairing the starter motor (shown on a Pantah engine)
https://www.box.com/s/pgaj1d0jmggrksbq7qqg
Casting your own front turn signal lenses
https://app.box.com/s/5zijl9qr6uqwkn77tcdi81kxcwk4zu77
Suspension & steering:
Marzocchi M1R fork manual
https://app.box.com/s/50abzqguic881iuynxr3539i8xshvqzq
Marzocchi M1R fork stop rings dimensions
http://www.box.net/shared/8r1zg2tlln
Marzocchi DuoShock service manual
http://www.box.com/s/yaishmk894lgxoazkxzj
new rear excenters for 17" conversion (17mm axle from a SS can be used, hence no need to machine the wheels to fit larger bearings)
http://www.box.net/shared/t89r5dk3cx
bar risers drawings and CAD files + video
https://www.box.com/s/930pnwe1c197vdapzcz1
Brakes:
tutorial on how to convert to 4 piston Brembo brake calipers incl. drawings and CAD files
https://www.box.com/shared/ugl1ifxe4n
brake adapters and some other info on 17" wheel conversion of P750/906
https://www.box.com/shared/lscrqbkkbx
brake adapters for 17" wheel conversion (calipers with 65mm mounting hole distance)
https://www.box.com/shared/lzd6kxnkgk
brake adapters for 300/320mm discs on Marzocchi M1R fork (calipers with 40mm mounting hole distance)
http://www.box.net/shared/gj6cbxn48w
Brembo P4 caliper dimensions
https://www.box.com/s/33qzf3qc1xyait4v1hvz
Luggage carrier systems:
mounting instructions for NonFango luggage carrier rack for 906
https://www.box.com/shared/0g50o8zqco
mounting instructions for Givi luggage carrier rack for 750/907ie
https://www.box.com/shared/4go2jdg17i
instructions for Givi universal mounting kit (for Givi wingrack carrier systems)
https://www.box.com/shared/t7ior2l62u
Hepco & Becker luggage rack (german description only)
https://www.box.com/s/te0lt03wrp15cfodnoyp
Ducati Paso 750:
P750 owner`s manual US version
https://www.box.com/s/pc5ghj6fdd7znlua884q
P750 owner`s manual multi language version
https://www.box.com/s/uuk8jf3je62bbu63q36o
P750 owner`s manual - California version (w/ Marelli Digiplex ignition)
https://app.box.com/s/88gjll751geb0iwxiz0n
P750 workshop manual
https://www.box.com/s/ged1902olfpn1i1lq5oa
P750 parts catalogue
https://app.box.com/s/jnbqq0149p83zybzu96sg812qbxpaa62
P750 wiring diagram (in colour)
https://www.box.com/shared/q1jdmz8ub9
P750 wiring diagram - California version (w/ Marelli Digiplex ignition) (in colour)
https://app.box.com/s/91fqn279mpwnv4kezfv6
P750 wiring modifications
https://app.box.com/s/waxvk1l9g47phfybd6n9
TÜV Bescheinigungen für Alternativbereifungen (german TÜV approval for alternative tires)
Metzeler/Bridgestone
http://www.box.net/shared/hft4b2yedq
Avon
http://www.box.net/shared/gq6hrzi9s4
Ducati Paso 906:
P906 owner`s manual US version
https://www.box.com/s/05bef79ua99adyspg5do
P906 workshop manual
https://www.box.com/s/mai2335dh4vl43q0efqn
P906 parts catalogue
https://www.box.com/s/anb97obn37pareletpkc
P906 wiring diagram (in colour)
https://www.box.com/s/cuv8nragt3z1vi0pw9pz
P906 wiring modifications
https://app.box.com/s/xzkocz2e7zcomsg40t7f
Weber mod and jetting for the P906
http://www.box.net/shared/q1x77snl9g
coolant reservoir modification
http://www.box.net/shared/ou0yii8jnc
Ducati 907i.e.
907i.e. owner`s manual
https://www.box.com/shared/kjkfr06a8c
907i.e. workshop manual (supplement to the 906 wsm)
https://www.box.com/s/jna5o7iamr6p6tq6fspq
907i.e. parts catalogue
https://www.box.com/s/lctqs86c8pvnxjp965v9
907i.e. wiring diagram (in colour)
https://www.box.com/shared/3elasen7q7
907i.e. wiring modification
https://app.box.com/s/64zvqpl6sf303gt44wu6
swingarm/brake caliper bracket pin - drawing
http://www.box.net/shared/jvp2dyz1h3
repairing the fuel pump
https://www.box.com/s/i8zgqnd7bdye1rofk1bg
adjusting CO trim
https://www.box.com/s/b2go9ga3sq6iq07lvg9a
adjusting TPS (throttle position sensor)
https://www.box.com/s/5a9zws9e2w31yhldlq1t
Unbedenklichkeitsbescheinigung für Reifenumrüstungen (german documents of compliance for alternative tires)
https://app.box.com/s/2bikt9sc0p1knplq1jrpha3stcp2jbhq
left and right swingarm decals (printable pdfs) (these are not for the P750/906 as the necessary chain slack is different!)
https://app.box.com/s/oo896rmygkkgl6gzj08cklpdd5uun0wy
Ducati 750S:
750 Sport owner`s manual
https://www.box.com/shared/pbgnkjcxlq
750 Sport workshop manual
https://www.box.com/s/s691kou2nhlb3b41bfcy
750 Sport parts catalogue
https://www.box.com/s/7p0bygcer4dy1bvwvl2j
750S wiring diagram in colour
https://www.box.com/s/d95nkk3uis04nzqdato1
750S wiring modifications
https://app.box.com/s/6mqf34acdyjfs9yhrc0m
http://www.box.net/shared/5wdgds288g
http://www.box.net/shared/6kbvqrfbh5
Ducati 900SS '90:
900 Supersport owner`s manual
https://app.box.com/s/s6d7qjaaite4dkps1o8672egq5fse0gb
900 Supersport workshop manual
https://app.box.com/s/7u0incfpwbpxw1dmyqv4
900 Supersport parts catalogue
https://app.box.com/s/8rb7ayuuif2qs7qncgo5kejzuwld1h3j
900 Supersport frame, swingarm and fork dimensions
https://app.box.com/s/x8e93h3dojj0wq8dzicth2dv2hb6es62
900 Supersport wiring diagram (in colour)
https://app.box.com/s/rqlews1vt1onid6b96bi
Miscellaneous :
Twist of the wrist 1&2 (pdf books)
https://www.box.com/s/8np98tuqzwzjv860j1xz
Reducing advance timing
https://www.box.com/s/iut6yms5nzsj7ofop60h
Primary gear locking wrench (diy)
https://www.box.com/s/16nf3ousc6f6vh06hkts
Alternator cover puller (diy)
https://www.box.com/s/5d4z2km8p9pewuk2765l
Toolkit contents overview
https://www.box.com/s/rgqeymo6uc8ezcphkiyw
Spark plug overview for big bore and HC kits
https://www.box.com/s/ed37m2l97ijfbvel33ve
Spark plug heat range crossreference chart
https://www.box.com/s/25we7ooqtng6ktcgwhxv
Overview of Marelli Digiplex units
https://www.box.com/s/ganl7i3ent8e6mznlc5g
Öhlins shocks service manuals
https://www.box.com/s/pdfatxijjvjcbnwca9jw
https://www.box.com/s/0dfl2mi1twovxonh98g4
Öhlins steering damper service manual
https://www.box.com/s/ur52u0iyc4os9u8377m1
label showing setup of California bikes / emission control regulation
http://www.box.net/shared/p9x1uzvrsl
Ducati Paso 750, 906 & 907i.e. Info zur Abgasuntersuchung (info for emissions control, relevant for Germany)
http://www.box.net/shared/eovf78q2dg
desktop background picture Ducati 906 - 1280x1024
http://www.box.net/shared/xg6l5ggjej#906_PC_background
Crankcase breather article
https://www.box.com/s/ispwmx1hd13pfn54iqj4
2 articles on exhaust systems
https://www.box.com/shared/4rd2q3kljs
article on engine oil
https://www.box.com/shared/h9fod6nisn
Italo Shop Neuss '93 Katalog
https://app.box.com/s/jakc6x6k2zmxqc1mgrmgbgfvm4cp7mfo
test of Moto Morini 350 Dart (Paso lookalike)
http://www.box.net/public/myrqgq2f0o
Ducati 851 888 manuals
https://www.box.com/s/8szdrpd317tsje263a16
Remote oil filler (drawing & pictures)
https://app.box.com/s/kohcxdnssrfnyywofb8q4289mqehizfy
Ducati 750 900 Supersport manuals ('91-'97)
https://www.box.com/s/23wv4czer9cvqqkp2woh
Ducati 750 F1 manuals
https://app.box.com/s/wq12jqesd32h5g017za2
Ducati Indiana 350-650 parts catalogue
https://www.box.com/s/z4fit23rjaud3qyf7bdq
Ducati ST2 manuals
https://www.box.com/s/mqr5iyf0av3nk1dt9dyn
Cagiva Alazurra 350-650 manuals
https://www.box.com/s/yx3dyrf2im8b2mlkx3k3
Cagiva Elefant manuals
https://www.box.com/s/58lxodw7ml4qeg86oxsv
Cagiva Freccia 125 C10R C12R manuals
https://app.box.com/s/nn436yoe1v0cdz2pxwftd2ll69ymnp0e
Reparaturanleitung Monster 600/750 & 900 ab ´93 (german only)
https://www.box.com/s/vyb1ckcgzys9s60myp8s
other motorcycle manuals
http://www.carlsalter.com/motorcycle-manuals.asp
http://www.manualedereparatie.info
http://www.pdfmotomanual.com/index.php? ... 8&lang=ENG
Ducati Paso videos:
http://www.box.net/shared/1k6dyg6hj6
have fun
 Post subject: Re: Paso magazine articles and other downloads
PostPosted: Sun Jan 07, 2007 5:03 pm
Great job, G. :thumbup: :thumbup: :thumbup: :thumbup:
It's a pity it isn't any Italian magazine, I had the Motociclismo tests of the 906 and the 907, but I'm able to find no more :sad: :sad: :sad: :sad: :sad: .
http://www.box.net/public/a11uib47gn
The Moto Morini Dart, more than a Paso, was a Cagiva Freccia with the 3 1/2 engine.
paso750 wrote:
Mike, Jon, is it possible to put a sticky on this post ?
Mike, Jon you have to stick it, or put in the download section!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
PostPosted: Sun Jan 07, 2007 5:07 pm
if you find them you know what to do :D
PostPosted: Sun Jan 07, 2007 5:10 pm
Yes, I do :thumbup:
 Post subject: Thanks Gerhard. You rock!!!!!!!!!!!!!!1
PostPosted: Sun Jan 07, 2007 7:28 pm
:thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup:
PostPosted: Mon Jan 08, 2007 8:43 pm
updated
btw. if anyone is interested in the original magazines (as a bulk, maybe per language) contact me via PM. Guess it won`t be interesting for guys outside Europe though due to shipping cost.
PostPosted: Tue Jan 09, 2007 3:42 am
I will work on it. How about a post in the FAQ to this in the meantime?
Jon
'88 750 Paso * '87 750F1
'04 Multi 1080s * '88 650 Indy
'65 250 Monza - Moto Giro Project
Click HERE--> 750 Paso Tech FAQ
www.desmoducati.org
www.ducatisuite.com
PostPosted: Tue Jan 09, 2007 10:02 am
Jon,
I could copy the first post on top to the FAQ and you delete this thread then. At least so I still could edit it.
A sticky though, leaving the thread here would be better as I don`t think guys check the FAQs so often as the rest of the forum to see if there`s something new and if one edits a post it`s not indicated as new/updated post.
Additional advantage would be that others can add downloads.
That would just bring confusion in the FAQs.
What do you think ?
PostPosted: Wed Feb 14, 2007 11:39 pm
Good work - thanks !
Rogero
1992 "Red" 907 I.E.
PostPosted: Sat Mar 10, 2007 8:39 am
I found a "motociclismo" (dec, 1996) with a complete test of 750paso.. hope I'll be able to share it soon!
PostPosted: Tue Mar 13, 2007 9:48 pm
thanks to Stefan (DuC-MaN)
one french article added (the one in the "aiming for apex" section, just in a higher resolution and as pdf.)
PostPosted: Wed Mar 14, 2007 9:18 pm
thanks to Hårvard (h1a)
added colour 907ie wiring diagram (in higher res as in the post in the 907ie section)
PostPosted: Tue Apr 03, 2007 7:34 pm
added:
thanks to "Ved": brake adapters and some other info on 17" wheel conversion in P750/906
PostPosted: Thu Apr 19, 2007 6:50 am
Thanks for the continued "good stuff"
Rogero
1992 "Red" 907 I.E.
PostPosted: Thu Apr 19, 2007 9:35 am
year: 1985
it's possible to translate the article of the german boy who did the 17 wheels conversion with 180 i'm so interested
