mrinflux wrote:Finn,Finnpaso wrote:Have YOU some problem with front sprocket???? Btw, i give You one advice: Stay there in philadelphia....
What are you talking about? Your 907ie has a chain? Amazing!!! All my 907ies are belt-driven!
Thanks for the travel advice. Unfortunately I've already booked passage back to Europe. I arrive in Helsinki on May 26th. Do you think you could put me up?
Elton
Replacement front sprocket for 907
Yank907
Re: Final-Drive Travel Advice
- Finnpaso
- year: 0
philadelphian guy .... smart aleck .... Make service to others: STAY THERE! ...Or If You cant, go then there, where u came! :funny: :funny: :funny:
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
Yank907
Yank,Yank907 wrote: Maybe you can drive a Fuel injected Monster while you are there??
The only way I'm getting on a Monster in Finland is if the front sprocket is compatable w/ a 907ie. I'm not sure...do you think you can use the front sprocket from a Monster on a 907ie? Maybe we should ask Finnpaso?! I bet he knows!
Elton
'91 907ie (Red)
'93 907ie (Red)
'93 907ie, w/ worked engine (Red)
'07 1098S (Red)
'07 MV Agusta F41000R
'82 Kawasaki KZ1100 Spectre (Wine/Black)
'93 907ie (Red)
'07 1098S (Red)
- persempre907
mjfrank907
Yikes, did I start this thread? I didn't realize it was that hot of a topic.
Just to add a little bit of clarity, I actually have two new sprockets, one I just got, a Sprocket Specialists 622-15, and one I got from Competition Accessories about 7 years ago, with the part number of 04082 SPCKT, Z15, C/SHAFT. The later looks like a factory part, as there is no manufacturer name, just an order, dealer, part, and bin number. Between the two I have, the 622-15 part number has a 1mm thicker shoulder on each side of the sprocket wheel (2mm thicker overall), and the 04082 part number has a 10mm shoulder on one side of the sprocket wheel, and no (zip, zero, zilch, nada) shoulder on the other side. The later would in no way work on a 907IE, the former one most likely will. (I wonder if the older sprocket I have is from a carb'ed Monster?)
I looked on Sprocket Specialists website, and the part number for the 95-99 900M is 523, and for the 00-02 900M is 622. (the one I have) So the earlier (and I guess carb'ed) monsters do have a different sprocket.
DesmoDog: Could you put a caliper on that sprocket when you get it? I'm curious if it's any closer to stock than the Sprocket Specialists one.
Thanks everyone.
--Mike
Thanks everyone.
--Mike
- DesmoDog
I finally got around to installing the new front sprocket today. It is approx. .005" (0.1mm) narrower than the original, which is close enough for me! The packaging says it also fits the 2003-2004 800SS. It looks wider in the pictures, but that's just an illusion.mjfrank907 wrote:DesmoDog: Could you put a caliper on that sprocket when you get it? I'm curious if it's any closer to stock than the Sprocket Specialists one.
Here are some pictures for people who don't trust anyone... (you know who you are!)
-Craig
- Stingray230SX
- DesmoDog
Yeah, I was pretty shocked to see it was that worn. Neeedless to say, once I pulled off the cover and saw that, I knew it was time for a new chain and sprockets, no question... ok, so maybe it was way past time for new one!Stingray230SX wrote:Looks like it was definately time to change that sprocket out!!!!![]()
-Craig
mjfrank907
Excellent find, DesmoDog, thx!
M900 carb 1993-99 front sprocket does not fit, tried today.
M900IE 00-02 had another sprocket, due to 748 gearbox w longer gear shaft.
The thing that matters is distance between toothed washer and centre of sprocket. If that is correct, it aligns and all is OK, no matter what the sprocket looks like. If done w a washer, no problemo.
My 2 cents... (or Marks, sorry... :laugh: )
