Wiring upgrade Choke/ idle issue
staticvoid1975
Hello All,
I purchased my Paso a few ago and am I quite happy I did so. However, I did have some issues with batteries being unexpectedly sucked dry and leaving me stranded. I did the wiring upgrade and I am happy to report that it worked out great and I now have strong spark at the coils at the massive dip in voltage I encountered previously is gone. However, when I apply the choke now the bike only revs at 1500, when before I believe it was up aound 3000. Also, after I have had the bike on choke for a few minutes and return it to idle it drops below 1000 and often dies. Any ideas on why the electrical mod affected this and what can I do to fix it?
Thanks for a hugely helpul resource for this bike and I hope to learn much more.
Ben
Ben
staticvoid1975
hmmm
Well, it looks like I have a bad regulator. Which may explain the residue on the exterior of the battery....hmmmm. I brought the wiring back to its original state and it ran as should. That said, I brought the bike up to 5000 and it hovered around 15.75 V and juice started boiling out of the top of the battery. I am gonna sort out the regulator before I try the wiring upgrade again. It took about two minutes to take it back to original! Anyway, thank for everyones help.
Ben
Ben
- persempre907
- Finnpaso
- year: 0
Regulator problem! But check also wiring from inside left cover... AND ALL charging system wires !!!!
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
- persempre907
- streetsurfer
staticvoid1975
- streetsurfer
