907 hot starting
907 hot starting
My 1990 907IE starts from cold ok, with aabout 1/3 choke but from warm or hot it fires up and cuts out refusing to start again until cold. Has any one expeienced this problem or can point me in the wright direction?
- Finnpaso
- year: 0
Hi!
I hope You remember also drive and accelerate very hardly, BEFORE You check You valve clearances! No need to check valve cl. if Your valves are very dirty! Many forget that very important point before valve check..... Engine must be as "clear" as possible before job
Here guys, who check other Ducks valves, do first very hard test drive to clear valve area from all shit...
...still thinking, that there can be some problems to figure out....
Finnpaso
Antti
Finnpaso
Antti
