Fuel Pump or Ignition Problem
Nomad
Post by Nomad »
I have a 1993 907IE and have run into a slight problem.
The bike starts to lose power, acts as if it is running out of gas, gets progressively worse until it will not pull itself in first gear.
Turn the ignition off and back on and the problem goes away for a while. If the kill switch is turned off the back on when the problem first appears, it corrects the problem for a few miles.
Has anyone experienced this and if so is it the fuel pump or the igniton?
Ducman
Post by Ducman »
check the fuel filter first
nicoducati82
Same problem!
Post by nicoducati82 »
My bike has the same problem as yours! Have you found the solution? I think that is something wrong with the injectors...you?
Thanks a lot!
Nicolas
