G-day pasomen chasing a set of clutch plates, any recommendations on who to contact.
thanks.
clutch plate availability
- du907
clutch plates
You can get them a the dealer, barnett, and others. The 907 comes with a steel clutch basket, so you will want steel plates, not aluminum. The steel basket will wear the aluminium tabs out much quicker. Also, if you ever replace the orginal 907 clutch basket, the updated basket is different than the original, it's not as deep and the retainer on the springs will rup the clutch cover, not to worry, use a 916 rubber gasket between the cover and the engine and it will give just enough clearance. My experiance is the orginals last longer, I have had barnett, surflex, and some others.
du907
du907
Re: clutch plate availability
bought clutch basket and barnett plates from desmo times,took only 1 week to arrive in australia and easy fit Brilliant.
