Water pump leak
steele
Water pump leak
Post by steele »
just discovered water coming from the little hole on timing cover :thumbdown: How easy is it to fix please :thumbup:
persempre907
Post by persempre907 »
That is a very common issue of our bikes.
You have only to replace the ring on the shaft.
It's quite easy.
Good work.
Finnpaso
year: 0
Post by Finnpaso »
Can U explane closer, from where that water is coming out? I fixed one time that "empting screw" thread from water pump cover with Helicoil system and it have been very good since. :thumbup: I have seen also some water pump covers for sale in ebay.
907IE -91 red/metal grey
907IE -91 red
steele
Post by steele »
Its the seals leaking i have some on order from Baines racing. Should be easy enough to fix now i have looked at it properly :thumbup:
persempre907
Yes, it will not to be a too much hard work!
