Oil Level Sight Glass
Desmo_Demon
Post by Desmo_Demon »
One of the many things wrong with my Paso is that the sight glass for checking the oil level is cracked and leaking. I have set out to replace this part, but Ducati has discontinued it some time ago (part #066049183). According to the parts diagram, it is the same part as the ignition timing sight glass (also discontinued), but there is a difference between them. The oil level sight glass has a reflector, but the ignition timing glass does not.
I have set out to find a replacement, but am having difficulties in the great land of non-metric parts. I have been able to find a replacement with appropriate dimensions, but it is made of plastic and not good for temperatures above 160-degrees F (71-degrees C). I found another with all the correct dimensions and temperature rating, except for one dimension......it is an M33 x 1.5 thread instead of the necessary M35-1.5 thread.
Anyway, I just wanted to see if anyone out there may have some leads on a replacement sight glass.
These are the dimensions that I've gotten for the part...
paso750 (Gerhard) has pointed out that a person is selling some on eBay out of the Netherlands, but I'm a cheap bastard and don't want to spend $50 USD plus international shipping for the part (at least not yet). The ones that I have been finding that "almost" work are in the $6-$18 USD range, so I'll pursue this a little bit longer until I give up.
Here's the auction that Gerhard found earlier...
http://cgi.ebay.de/Ducati-Pantah-Sport- ... dZViewItem
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
Finnpaso
year: 0
Post by Finnpaso »
Can such made with lathe from aluminium??? I think, if find good guy for that, its maybe best solution. Surely that coast also little... :evil:
907IE -91 red/metal grey
907IE -91 red
20YearOwner
Post by 20YearOwner »
Oil level sight glass, mine has been leaking for several years, currently I have come to believe the best I can do is find a salvage shop that will sell the cluth cover with the glass in place, I have a shop in CA looking for one today.
Desmo_Demon
I've been looking into making an M35 x 1.5 to M27 x 1.5 reducing bushing to adapt a sight glass that I found in an M27-1.5 thread. I've also been thinking of making a small "V" notch on the cracks in the lens and filling them with a clear epoxy to try to stop the leaking.......I'm still researching alternatives. :D
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
from Germany
PS: good luck btw :D
RADDUCK
Oil Site glass Idea
Post by RADDUCK »
Just an Idea... You said the only difference between the Magneto side and the dipstick side was the reflector. If yours is cracked what if you salvaged the reflector from it and installed it on the good plug from the magneto side. Or just skipped the reflector all together. Scribe in some marks and check your oil with a flashlightThen you could source an appropriate threaded plug for the magnato side, & add a rubber oring. Just pull the magneto plug when doing valve adjustments.
RADDUCK
02 Honda RC51 SP2
87 Paso 750 - Dropped but ride-able
03 Triumph Bonneville - Basket case (resto in the works)
88 Porsche 911 Carrera
04 Subaru STI
Desmo_Demon
Re: Oil Site glass Idea
RADDUCK wrote:If yours is cracked what if you salvaged the reflector from it and installed it on the good plug from the magneto side. Or just skipped the reflector all together.
The reflector would have to be cut out, since it is plastic welded into place. I'm thinking of just switching the two, for now, since the ignition timing glass is not submerged in oil, so the cracked one will not cause any problems in that location.
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
wilbur
Post by wilbur »
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0175624460
Just saw this, sorry didn't find it sooner. Good seller too. I bought parts from him before.
Tim
Port Murray, NJ
1987 Ducati 750 Paso
1995 Ducati 900SS SP
1999 Ducati 996
1998 ST2
2000 Honda RC51
Finnpaso
year: 0
Post by Finnpaso »
I can buy from here just suiteble "oil glasses" from hydraulic part shop easily. Price is about 10€ and thread is same. It looks little diffrent, but do its job very well. I saw just yesterday eve one suchkind in one 750 Paso here.... There is inside also sameking metal plate, what original have also.... :evil:
907IE -91 red
