Replacement of front wheel bearings
- JWilliam
- year: 1989
Do any Paso owners have tips for removing the front wheel bearings? It is made difficult by the bearing spacer that covers the bearing internally and prevents use of a punch.
hey, you forgot to post in the 907ie forum
maybe this`ll help:
http://members.aol.com/TBoling125/paso_project_7.html
maybe this`ll help:
- Desmo_Demon
I think this is the key item on that page for front wheel bearing removal...paso750 wrote:hey, you forgot to post in the 907ie forum![]()
maybe this`ll help:
Here's another of the swingarm pivot bearings, which are similar to the wheel bearings (actually, the bearings are the exact same part #). This diagram may help with showing the location and relationship of the components in the wheel hub. The outer race support is built into the wheel hub, instead of a separate part, as in the swingarm....
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
- Desmo_Demon
I had a friend of mine make a drift to drive the bearings out of my front wheel. He used a hydraulic press to evenly apply pressure to remove the spacer and bearings. There was no deformation of the spacer at all, so it can survive many bearings changes. Ideally, the drift should have an outermost diameter just under the 20mm inner race diameter of the bearing, and then step down to fit within the 17mm inner diameter of the spacer (the axle is 17mm, whereas the bearings have 20mm races, which is why this spacer is designed the way it is).JWilliam wrote:I dont think the spacer will survive more than one bearing change so I might cut off the thin wall over the inner bearing face and make two slip on bushes.
To modify the spacer the way you want to, you may want to make a correct length spacer for the hub that is of 20mm ID, then make a bushing that is 1-2mm shorter than the overall length of the distance between the outside of each bearing. There are several ways to do it, though.
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
