906 907 bodywork on 750
- year: 0
Is it possible fit 906 or 907 bodywork on 750?
Re: 906 907 bodywork on 750
906 body work will fit but as it is watercooled the radiators are bigger. Vice versa you would need to cut the opening of the side fairings where the radiators are stuck in if you would try to use 750 fairings on a 906. At least that is what I was told, never did that myself.
As far as I know the 907ie uses the side fairings of the 906, although it has the radiator on the front.
Rear and rear side panels are interchangeable. Using 907ie screen requires different foam surround of the instrument panel.
Gerhard
Gerhard
- persempre907
It's so. The 906 & 907 fairings are the same except for the screen.paso750 wrote:As far as I know the 907ie uses the side fairings of the 906, although it has the radiator on the front.
- Finnpaso
- year: 0
907 and 906 fairings are quite different ones(also compared to each others, mainly in front part)... I think, its quite complicated to swap another fairings to 750 Paso,but surely can be done with fiberglass jobs. I have done one 906 front fairing from fiberglass for dual headlights to my 906 friend. He is satisfied to my work..
But sorry, guys, no fotos without his permission...
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
what`s the difference ?907 and 906 fairings are quite different ones(
- Finnpaso
- year: 0
Sorry, i remembered wrongly, only difference is that spoiler system in front fairing. I mixed things: I mixed 750 front fairing to 906/907 fairings... My mistake!
907IE -91 red
907IE -91 red
he he, you were about to make me sweat
- Finnpaso
- year: 0
Dont worry, Gerhard, You can do it easily...("fight" Virgo against Germans,hahahahah) I start to be too old and tired man...paso750 wrote:he he, you were about to make me sweat![]()
907IE -91 red
907IE -91 red
- persempre907
Antti,
you only have to have a little less
- Finnpaso
- year: 0
Frankie dear, as I told, i start to be old man and i havent had time "to enjoy" so much in my life(cause spent too much time with Ducatis, making big house, etc...), so i think ill take just right amount of
NOT "so much", as You think...
No matter, Your advice was very healthy...
907IE -91 red
907IE -91 red
- persempre907
Antti,Finnpaso wrote: I havent had time "to enjoy" so much in my life(cause spent too much time with Ducatis, making big house, etc...), so i think ill take just right amount ofNOT "so much", as You think...
there are very many good things you can "enjoy" in the life without any effect on the memory...
