I took some measurements, and using the 750's axle is not possible with a 907 swingarm.ducapiero wrote:BUT I HOPED TO MOUnT MY OLD AXLE![]()
The 907's axle is 350mm long with the non-threaded, center section being 305mm in length. The total length of the stock 750 axle is only 280mm. There is only about a 3mm difference in the internal width of the swingarm between the swingarm's forks, but with the adjuster eccentric's design, the 750 axle is shorter, whereas the 907's axle needs to protrude beyond the outside of the swingarm.
