What chain for 87 paso 750
nickapaso
Post by nickapaso »
Hello, I recently bought an '87 paso 750 and have new sprockets for it and want to replace the chain as well. One shop told me it used a 520 106 link chain, and another shop said to use 530 108 link. I have a new 38 tooth for the rear, and a 15 tooth for the front. Anyone know?
nilaus
year: 0
Re: What chain for 87 paso 750
Post by nilaus »
Hi
http://www.motorcycle-road-and-race.co. ... _id=405832
DID Chain and Sprocket Kit - DUCATI 750 PASO SPORTS 86-90
Front Sprocket: 15 teeth.
Rear Sprocket: 38 teeth.
Recommended Chain: Pitch-520 Links-106
mike
Post by mike »
Note some very early pasos used a different chain (520?)
Type DA-OR 136 up to serial number 750130
Type DA-OR 135 from serial number 750131
Finnpaso
year: 0
Post by Finnpaso »
I think, MOST of 750 Pasos use 520 chain/sprockets... :cool:
907IE -91 red/metal grey
907IE -91 red
paso-passion
Post by paso-passion »
"530" etc. is the pitch and width of the chain measured in units of one-eighth inch, so 530 is 5/8" pitch x 3/8" wide. Similarly 520 is 5/8" pitch x 2-eighths, i.e. 1/4" wide. (D.)
According to Ian Fallons book 750 Pasos up to frame No. 750130 had a 5/8x3/8 chain while from framenumber 750131 a 5/8x1/4 was used.
So early Pasos had a 530 and later ones a 520 chain. (G.)
(Cross-post from http://forums.ducatipaso.org/viewtopic.php?f=1&t=2161)
