I haven't been riding my '87 750 Paso in a while (2 yrs)
Here are the details with the battery fully charged (~ 13V)
- Brand new battery
- Sometimes won't start with voltage less than 13V
- Current draw from battery with engine off, with various ignition positions:
Locked: 0 mA
Park: 1.2 A
Off: 0 mA
On: 4.8 A
Note: This seemed reasonable to me due to power consumption of lights (5-60W)
- Voltage across battery, with various ignition positions (particular instance):
Locked: 12.9 V (steady)
Park: 12.7 V (dropping @ ~ 0.01V/s)
Off: Same as Locked position
On: Plummets @ ~ 0.1 V/s
Note: On position seems excessive!!
- Voltage when running, at various RPM:
1K: Drops steadily from the On position voltage @~ 0.05 V/s
1.5K: Greater than 1K voltage, but less than 2K, and steady
2K: 13.8 V (steady)
2.5K: 13.8 V (steady)
Note: Performance at 1K clearly indicates the draining of my battery
- My wiring is a little scary, as there are loose leads that I am not sure are necessary or not, yet (used bike)...just being honest
- I've spent a decent amount of time cleaning grounds and contacts under the seat, but hadn't got to the electrics in the front of the bike, e.g. electrical panel, key ignition, etc.
Any clue what may be the fault? One idea I had, was possibly a short in the ignition wiring? I was also thinking about bumping up my idle ~200-500 RPM...I'm not sure if this would end up being the real fix, or a fix that would mask the real problem? Any ideas would be appreciated!
Thanks,
Michael
