After a long search with the INCOMPITENT folks at ATLANTA DUCATI, and a mini lecture from the folks at the DUCSHOP, about how I shouldnt expect to find parts for the 907 due to it being 15 yrs old. When the fact of the matter is DUCATI parts distro for older bikes is for CHIT!!!
The BMW K1100's use a 41.7mm Marzocchi Fork. AND guess what? It uses the same seal as the 907 fork!!
BMW sells the part for $12(each) verses $24(each)!!! from the DUCRAPPY SHOP. This is the same part from Marzocchi.
fork seal source.
- ducbertus
Re: fork seal source.
Thanks.
Maybe it's worth to look at BMW for slides as well, because mine pretty worn out.
Ducbertus
Ducbertus
Debonair
I believe that the fuel pump and filter are also the same....Oh, and brake pads....
