Dellorto fine tuning
- Desmo_Demon
Re: Dellorto fine tuning
I'm running the Dellortos with K&N filter pods. Is there supposed to be a lot of intake noise with this setup?....I can heard the air being "gulped" into the carbs as the bike idles, and it's fairly loud.
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
- Skins
My only experience is with Malossi equipment. I keep my filter sponges well oiled, and the intake noise when idling is hardly noticeable. I can sure hear the suction under acceleration, however.
Another thing to check with Del Ortos is that the choke piston system is sealing well, with plenty of slack in the choke cable, so that it's not influencing the mixture when not required.
Also, I have heard that Ducatis with two-into-one exhausts are not so easy to tune, although I can't see why that should be so different to the Paso's two-into-one-into two system. I have a mate with a late model tuned 750 Sport (fuel intected) with a two-into-one system which makes heaps of power and runs well.
- Desmo_Demon
The gulping noise wound up being a choke that was not closing conmpletely.Desmo_Demon wrote:Is there supposed to be a lot of intake noise with this setup?....I can heard the air being "gulped" into the carbs as the bike idles, and it's fairly loud.
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
- jcslocum
These carbs are finicky! I found that the intake had a lot of sweet sounding HONK when on the throttle. I had the same set up with the K&N's. I liked the sound.
