Cluster lighting
Cluster lighting
Has any one tried the new led 194 bulbs? Dont want to swap to the higher output 168 bulbs as I,ve had heat issues with them in the past in other clusters which are much easier to replace than this ducati one. Found a set of 20 on ebay for 17 bucks,figured I'd give them a try
DonaldoDuck
Re: Cluster lighting
Post by DonaldoDuck »
Please let us know how they work. Thanks. :)
1992 907ie Beauty. Custom high pipes, Pro Italia chip, Barnett performance clutch, Corbin Seat, Stainless brake lines. 35,000 miles. Owned since 1993.
Will do,sometime next week. Did a little research around the web,some guys like them some don't. From what I was able to determine the folks that are unhappy got the blue ones.The ones I ordered are pure white so I am hopeful........
Bulbs finally arrived.Put 2 in. First impression is they are not very bright. Not even as bright as the old 194's I replaced. They are much whiter. I am currently waiting for hurricane Hannah to move on so I can give them a rode test.
Finnpaso
year: 0
Post by Finnpaso »
Put Your Paso to safe place! :thumbup: I hope, that damages are not big... :thumbup:
907IE -91 red/metal grey
907IE -91 red
