number of chain links ?
I recently looked through a fitting chart from REGINA chains and got confused. It says:
750 Paso 87
15-38-106 (530)
750 Paso 88-90
15-38-110 (520)
906 Paso 89
15-40-108 (520)
906 Paso 90-93
15-38-106 (520)
907i.e. 90-91
15-40-108 (520)
907i.e. 92
15-40-108 (520) but with a different order number
Now I guess there must be some things wrong here. I can understand that with a 40 tooth sprocket a chain is used that is 2 links longer, but I`m wondering that the 907ie uses the same chain length as a 906 although it has a longer swingarm and I also think the data regarding the P750 is mixed up.
What`s the correct chain length for a P750 (520 chain) and a 907ie ?
Finnpaso
year: 0
Re: number of chain links ?
Post by Finnpaso »
I never look so closely those tables, cause there are near allways mistakes in them. I use normally much bigger in rear in my 907, so allways, when need new chain, i count, how long chain i have and i check, in what position is that adjustment in swingarm.... "its in brains, not in tables" :thumbup:
btw, if u need to know my combination, i count and tell it to You.... :thumbup:
907IE -91 red/metal grey
907IE -91 red
I do still have the old chain of my bike so I can check that myself, but could you check the length of the 907ie chain ? Thx.
Finnpaso
year: 0
Post by Finnpaso »
Just from sauna, so very tired after :beer: , but tomorrow i let u know my sprockets/chain lenght.... But i use big rear sprocket in my 907!!!! I dont need top speed, but i want hard acceleration and good gearbox ratios in twisty roads... :thumbup:
907IE -91 red
Finnpaso
year: 0
Post by Finnpaso »
I use this combo in my 907IE:
Front: 15 (original)
Rear: 46 (!!!)
Chain: 112 links
And adjusting in swingarm is in "quite front position", so there is free play still alot for tighten chain, when it gets older. :thumbup:
907IE -91 red
