parts again!
desmodave
year: 0
parts again!
Post by desmodave »
parts again! does any one know if the ss rear master cylinder is same as 750 paso? and also speedo cable/ desmodave
Re: parts again!
No it`s not. The mounting hole distance is 40mm instead of 50mm but maybe an adapter plate can be made ...
If I remember well the speedo cables is too short. I had 2, not sure if from Supersport or Monster and both didn`t fit.
desmodave
year: 0
Re: parts again!
Post by desmodave »
ta for your quick reply g.
redmidget
Re: parts again!
Post by redmidget »
Replacement speedo cables can be ordered from http://www.mdinaitalia.co.uk. Less than £15 and very quick service.
I replaced my rear cylinder with this one but you do need to make up a plate to cater for the 40mm spaced holes.
http://www.intobikes.co.uk/products?det ... 92&search=
Re: parts again!
do you have a picture or drawing of the plate ?
redmidget
Re: parts again!
Post by redmidget »
There are 2 photos and a diagram attached. It's difficult to get an angle for a clear photo but you can get the idea.
Three holes in a plate;
bottom cylinder mounting bolt goes through lower hanger hole, hole 1 in plate and lower cylinder mounting hole
top cylinder mount is secured with countersunk bolt through hole 2 in the plate
hole 3 in the plate is used to secure top end of plate to upper mounting hole in hanger
Hope this helps
Centre 1 – Centre 2 = 40mm
Centre 1 – Centre 3 = 50mm
Hole 2 countersunk on one side
Finnpaso
year: 0
Re: parts again!
Post by Finnpaso »
Great! Thiskind i like very much... :thumbup:
907IE -91 red/metal grey
907IE -91 red
