front brake light switch
desmodave
- year: 0
where is this located? I have something missing near the lever two holes. what is the stop switch on the parts cat. in between the front brake hoses? is there meant to be two parts for you front brake light? .....desmodave.
- ducapaso
Re: front brake light switch
it's mounted close to the inner triple clamp, in the 3way joint.
It's not easy to see with the bodywork installed
Have a nice work, and...
ex...Red "smooth" 753349
Dave,
the brake pump is used on numerous other bikes. There may be bikes that don`t have a pressure switch and require a small switch at the pump instead. You don`t need both.
