Right, first job now the bikes home is to change cambelts. Ive some on order, waiting for the postman. Heres some pics of the condition when i took the covers off :
The centre / crank pulleys:
The horizontal belt:
The vertical belt:
The bike had been standing for quite some time before i took it home, and no idea when belts last changed, but there didnt sem to be any major concerns or damage to them. However, there is a load of crap around the vertical cam pulley - not sure if its old rubber or oiley dirt (any way it will all be cleaned away nefore the new belts go on) :
Cambelts - before changing
- Finnpaso
- year: 0
Re: Cambelts - before changing
I am QUESSING now, that someone have tighten too much those belt cover screws, then that rubber start to turn and it can hit to belt and grinding start. I noticed thiskind one time, when i turned those screws too much and then that rubber part started to turn and belt touched that rubber and started to make some noise.... I opened immdiatelly covers and find small part of rubber gone away already... As I say, this is quessing.....
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
- Desmo_Demon
Chances are, that is rubber from the belts. I've seen this with my ST2 when I went 12k miles without adjusting the belts. I adjust the belt tension every 6k, now (the bike has 36k miles on it and I only do valve adjustments every 12k as the valves have settled and I skip a valve check/adjustment).anton88 wrote:However, there is a load of crap around the vertical cam pulley - not sure if its old rubber or oiley dirt (any way it will all be cleaned away nefore the new belts go on) :
What happens is that the belts stretch and get a little loose. When the engine is not up to operating temperature, the belts are still a bit more loose than they should be. When you go riding and chop the throttle, the belt flexes and hits the belt cover. If you inspect the smooth part of the belt, you'll probably see a groove where it has been hitting the cover.
This is what my belts looked like when I got my Paso....
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
- Finnpaso
- year: 0
It can be also so, as U say....
Also all pulley(and "lead rollers" bearings) must be roll easily without too much friction. I have seen many Ducatis, what have lost those bearings and then its again bad thing.....and very harmfull to belts.....
907IE -91 red
907IE -91 red
- ducapaso
This might also be the right time to make an accurate ceck to the bearings and wonder if it's bettere to upgrade to roller/bearing alike newer desmodue
ex...Red "smooth" 753349
Changing belts, its really and easy project when you have the manual. Also go to Ducatitech.com and see the video.
- year: 1989
Thanks for the tips Guys. Upon closer inspection, its definitley a mixture of dirt and rubber, but i think its accumulated over quite some time.
I havent fitted the new belts yet, as the engine is coming out for a thorough clean degrease and bit of paint before checking and replacing any parts. I can see that the vertical belt has been rubbing on something (not by much), but cant see where yet - should be able to see where once its all clean.
wouldn't hurt to change the oil seals behind the cam pullies , probly should do the ones in the clutch too
