Some people already did it.sungamma wrote:So, if I KEEP the 907 heads and just install the cylinders and pistons, then NO machining is required? Pure bolt on? Want to make sure I get this right before I make the investment.....
They say (my mechanic, too) the ST2 cams are a big improvement for the timing.sungamma wrote:BTW, are the ST2 cams an improvement over stock 90 pieces?
Thanks all.......
