No Spark
Locked
germantrader10
No Spark
Post by germantrader10 »
What do i do Battery is good and new
Fuel is good pump primes?????
Re: No Spark
I thought you had no ECU :huh:
Laddie907
Re: No Spark
Post by Laddie907 »
It might help to put in a bit more of a description of the problem...
like was the bike running and then just "stopped dead" or began misfiring or was it bought "not running" and you're trying to get it started...or maybe a friend borrowed it...
if you mean "no spark" suggest to:
1. check the kill switch is set to "RUN"
2. pull a plug and EARTH it to frame, then test...
3. check power to both coils
4. check power to both ignitors (be careful with earth)
5. check crank timing sensors
if you mean "won't start"? check the compression...
Re: No Spark
also check each coils reisistance, I just had one crap out on me.............
Locked
