Ignition Barrel Required?
- jcslocum
Re: Ignition Barrel Required?
Well, if Juan comes back maybe he will tell us what he bought to fix his problem. I'm fairly sure that no matter what we call it, it's the thing that turns the bike on and off.
Whatever he needs or wants to call it I have the whole assembly for a 906 without a key,at least I don't think I have the key.
the ignition key switch of the P750 and the 907ie is different. The height is different as are the mounting holes and I guess the 906 key switch is the same as the one of the P750
- Finnpaso
- year: 0
Someone to check from microfilms, what are ordering numbers?
I am too hurry now, cause i have to change rear schocks to my Passat... Its "too" old one, next i will buy Volvo V70 Bi-fuel...
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
- persempre907
The number of the 750's key switch is 067038690.
The number of the 907's is: 65240031A.
Gerhard has plenty of experience in such things and he knows very well those switches.
906 is 65240011a
- Finnpaso
- year: 0
So, all are difeerent
..."Ducati design"...
907IE -91 red
907IE -91 red
- persempre907
As you can see, the kind of the numbers of 750 and 906 is different.
So, I would not be amazed if the 750's and 906's switches were identical
yes the 750 and the 906 are very different, but the 906 and the 907 look like the same series,very similar so what is the difference?
906 is 65240011a
could be just the key style,but I don't really know
906 is 65240011a
- persempre907
Gerhard has already replied above.higgy wrote:yes the 750 and the 906 are very different, but the 906 and the 907 look like the same series,very similar so what is the difference?
906 is 65240011a
P.S. The 906 and the 907 are very similar. The 750 is very different from 906 and 907.paso750 wrote:the ignition key switch of the P750 and the 907ie is different. The height is different as are the mounting holes and I guess the 906 key switch is the same as the one of the P750
does anyone have a picture of a 906 key switch ? Does it look like the left or the right one below ?
here`re on the left is a 907ie switch and on the right one from a P750 (sorry, the pics are not really good)
Here is what I have for now,will send more after i deal with the breakaway bolts
I think what is important here is the mounting and the electrical connector maybe the lock for steering. My guess is since the number are so similar the difference is something outside of the way it mounts...justa guess tho
- Finnpaso
- year: 0
Gerhard: I have totally another looking (spare) key lock from wrecked 907, than in Your foto(that "907 key lock")!!! my looks quite similar, as Your "750 key lock"....
I can take foto from that and send it to You, so You can add it to this topic?
I am little ashamed, cause i cant send fotos to these sites, cause i have huge amount of good pictures from my Pasos and spare parts, mods, etc... but one reason is, that i dont have enough time to do all, what i want...
907IE -91 red
907IE -91 red
the 907ie lock on my picture is the same as the one from the lock set on ebay
That 906 lock looks as high as the P750 lock.
Antti, you can mail me your pics.
- persempre907
My 907s have different key switches.
The "newer" one has the same switch as in the Gerhard's pics.
The "older" one has the edge smooth and not furrowed.
Besides, the keys are different, so that the key of the newer doesn't fit into the older and viceversa.
