greetings from a 906 owner
Re: greetings from a 906 owner
Post by Tamburinifan »
how have you modded the headlamp?
+1, I don`t even see it. :shock:
Kurt
Post by Kurt »
The answer to your question is in another thread
http://forums.ducatipaso.org/viewtopic. ... 758#p23758
timmetje wrote:thanx! i used an old headlight from a ford scorpio, i put some pictures in the greetings from a 906 owner post
- Kurt
If you look closer at the picture he posted earlier you can just make it out in the lower part of the painted"windscreen"
Thx! :thumbup:
timmetje
Post by timmetje »
ok, here it goes
filling with foam
then i put polyester on the foam
polyester primer
more primer and a lot of sanding (dont do it in the living room lads, your wife will kill you!
the headlight unit from the scorpio, slightly modified
sanding painting sanding painting, etc, etc
keeps you of the street
which is all that matters :thumbup:
timmetje
Post by timmetje »
JWilliam wrote:Tsubaki chains are rubbish, stretch stretch stretch. I don't think much of 'O' ring chains either. They are OK for a summer but once the inner lube is dried out they sap a lot of power. I use DID super NZ 520 non 'O' ring. Super strong. Like the bike, how have you modded the headlamp?
is there so much difference between the non o en o ring chains? my next chain would be a DID anyway (bad experience with the tsubaki :,( ) but also because im converting to 17"wheels while keeping the old rear fork, it would be nice to have a minimum "stretch"
JWilliam
'O' ring or non 'O' ring
Post by JWilliam »
My main criticism of the 'O' ring chain is the greater width of it and that there is a distance between the inner and outer link plate because of the 'O' ring. Meaning that there is more chance of the pin bending, allowing the outer link plate to drift off the pin causing the chain to break. Not only that but when oiling an 'O' ring the lubricant isn't going to get past the 'O' ring - because thats whats its there for - so they are only so good for so long. Race teams love them because the lubricant won't fling out but they change them each meeting. What we want with them is beyond me.
timmetje
Post by timmetje »
so, tomorow i'm gonna pick up my new front brakes, brembo goldlines, the 65 mm type and thanks to this wonderfull website i've got all the drawings i need to make this thing work, so a big thumps up for all you people who share you're problems, solutions, frustrations and love for this great motorcycle.
timmetje
Post by timmetje »
nice!
ok!! the 900ss wheels are back with the new bearings in it and it fits the old axle of the paso, lets see how much work i can do to put this baby back on the road!
(unless my wife gives birth! what could happen any day now.
timmetje
Post by timmetje »
What type of chains do you prefer & why?
timmetje
Post by timmetje »
for now i'm going for the DID 520VM chain, but i got it for free from the shop where i bought the last one, owner felt sorry for me because te last one broke.
so he gave me a new set, chain and chainwheels.
persempre907
Post by persempre907 »
timmetje wrote:for now i'm going for the DID 520VM chain, but i got it for free from the shop where i bought the last one, owner felt sorry for me because te last one broke.
:shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
Did you have some problem with the case???
I fitted two stainless steel protections to avoid any such issue.
