How to remove rear wheel?
748ducdude
I need help please. I just purchased a 1988 Paso 750. Can someone tell me the correct procedure to remove the rear wheel? I do have the large allen wrench from the tool kit. I am guessing you start by loosening the pinch bolts? Then what? Thank you
- Desmo_Demon
Re: How to remove rear wheel?
To make things a little easier, I always remove the two brake caliper bolts and slide the brake caliper off of the rotor, first.748ducdude wrote:Can someone tell me the correct procedure to remove the rear wheel? I do have the large allen wrench from the tool kit. I am guessing you start by loosening the pinch bolts? Then what? Thank you
I generally will leave the pinch bolts tight until I break loose the right (brake side) nut on the axle (if you loosen the pinch bolts first, you can get the whole assembly to rotate in the swingarm). Then, I loosen the left side pinch bolts and knock-out/slide the axle out from the left side of the bike with the accentric still attached. I do this to prevent any possible binding between the rear brake bracket and axle. For some reason, I have had some issues with that happening, which makes removal of the axle a royal PITA.
Once the axle is out, you have to roll the wheel forward, slide the chain off of the sprocket and move it over the swingarm a little to clear the sprocket. Then lift the brake caliper bracket out of the assembly, and roll the rear wheel out from under the bike.
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
748ducdude
THANK YOU! Piece of cake. Did it already. The $*&^% Ducati factory repair manual lists step by step instructions and tells you to loosen pinch bolts first. Argghhhh.
