Hi all, the front brake lever on my 907 is damaged at the end. anyone know if they're still available??
I've seen copies but none with the brembo badge in them.
original front brake lever still available ??
- persempre907
Re: original front brake lever still available ??
They are still used by many new bikes.
So, you'd have to find them easily.
- 93IE
- year: 1993
I just purchased a new one with a new front master cylinder from Yoyodyne. Entire assy. was about $100 with freight. Lever was identical to the one that came on the bike. They have a catalog on the web, and am sure you can buy just a lever.
Good Luck
Preston
Good Luck
Preston
- Desmo_Demon
Many of the newer Ducati's with the "coffin" style master cylinders use the same levers. I know that the ST2/ST4 use the same levers up to '02. The problem is that most of those are silver and not black. If you want black ones, I think www.bevelheaven.com sells what I believe to be original Brembo levers in black for around $25-$30 each.holla wrote:Hi all, the front brake lever on my 907 is damaged at the end. anyone know if they're still available??
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
