I found this cap on the net which might be a good alternative to the CB600 unit
comes with a 0.9 pressure relief (saves finding another cap)
http://www.frozenboost.com/product_info ... ts_id=1064
any thoughts from those who have done the conversion???
I'm just about to convert and am having trouble finding the Honda unit.
Remote Radiator cap option....???
Re: Remote Radiator cap option....???
Are you having trouble finding the filler neck or the 0.9bar/13psi cap?
If you are contemplating using that whole assembly .... I'm not confident it would fit.
- Laddie907
well, I bought one and fitted it...
it lives above the plastic filler tank and can be accessed / opened / filled by removal of the front fairing around the headlight...
some minor plumbing required...but at least the hoses are available...the Ducati OEM hose will be difficult to replace.
I will post some pics later...
