An option would have been to machine the hub diameter of the rim from 40 to 42mm and use standard size Paso wheel bearings SKF #63004-2RS or to get a 907ies swingarm of course. Then you also wouldn`t have to modify the swingarm to add the pin that holds the brake caliper bracket.It was not possible to use the old shaft, because of there are no bearings there will fit in the wheel Ø 40 mm with a 20 mm haft
The speed gear has a ratiio marked on the external surface: same box for different ratios. If you search in the site, you'll find a rumor about Aprilia 125 RS application.Ken@Murayama-Paso wrote:Does it use a normal speed meter?
I got new 17 " shoes converted from 400SS to my paso750 recently.
http://ameblo.jp/ducati750/entry-10353122117.html
But I have a problem with speed meter. A large margin of error came to occur as 100km/h indication at the time of 80km/h.
The speed meter is for normal 750paso. The speed meter gear is for 17 " 400SS(I think it's same one as 600SS).
How did you do it?
I checked it out immediately.ducapaso wrote:If you search in the site, you'll find a rumor about Aprilia 125 RS application.
At first, I felt that the rudder response became slow. It can be expressed "stable" and "normal without the characteristic particularly".ducinthebay wrote:How is it in corners compared to what you had before?
