As You Frankie know very well, all bikes have little different setups, so "thing" (to make 100% perfect chip/eprom) is not so simple like "to burn good eprom to fit all bikes"...persempre907 wrote:Now, we only need for the right map to burn the eprom![]()
If you think so, you are wrong, as i dont resist at all your project. I only wanted to say what i am thinking about this "thing". Still i am thinking that every 907 need little different mapping, so any "universal chip"(average chip) is not the best if you want best performance... but if looking "something good" it can be good choise to know data of all 907ie chips , compare data and make choise and burn chip...and test.. and test and maybe burn another chip and test..... this is such thing, that if really want to know then it takes time and tests and good equipments and that "knowing".... sometimes all goes well and other time its big wet swamp.... also often "more knowing means more suffering"higgy wrote: I really don't understand your resistance. It is futile!My friend
