My question comes from replacing clutch discs and then realizing that I didn't need to remove my pressure plate which I did of course. My assumption was to tighten the pressure plate's six bolts all the way. Upon doing this I had no action on the pressure plate via the clutch lever. So I backed out all six roughly 4 turns each and had action on the pressure plate via the clutch lever but it would not completely release the gear with the clutch lever fully pulled in. Obviously I didn't observe the original position of the six pressure plate bolts before my initial dis-assembly so I have no idea if they where originally tightened all the way down.
So any input would be a help at this point (sun's down - dinners ready). I am prepared to back out the six pressure plate bolts to roughly 5 to 6 turns and use some thread locker on them. But I'm wondering if the sweet spot is somewhere between fully tightened and 4 turns out? Hmm . . .
Of note is the fact that my 750 is also suffering from wear on the contact point between the clutch's slave piston/puck/bearing and the pressure plate center point/pin, which, of course, has broken itself loose from the welds holding together with the pressure plate. WHEW!!!
