Hi
looking for the SKF front wheel bearing number code.??????
So this info also comes up later in a search the rear is
SKF 62203-2RS-C3
ta
Nige
907 front wheel bearing number?
- blazing928
Nigel
91 907IE - full restoration
MPL Slipper,Ceramic exhaust
Lambretta LI150 S3
87 928S4
Lambretta LI150 S3
87 928S4
- Jaffa
Re: 907 front wheel bearing number?
http://ducatipaso.org/docs/907/manuals/ ... atalog.zip
Nige,
If you follow the link, it will take you to a parts manual. It is U.S but is useful. Also available is the workshop manual for the 907, bear in mind that you will also need the 906 manual as that is the basis for the 907.
You are able to download the lot to your computer at will.
Nige,
Jaffa
'91 907ie (RED)
'82 900 Mike Hailwood Replica
Volvo aware Motorcyclist
'91 907ie (RED)
