I've found a 91-97 Supersport / Superbike / Monster / ignition switch and I'd like to know if I can use it to replace my 750's switch. I don't have a problem splicing wires and all. I just want to know if there are any unforeseen issues I need to know about.
Thanks all . . . Ethan
'91 to '97 ignition switch
- fredskidoo
'87 750 Paso 751412
- ducinthebay
Re: '91 to '97 ignition switch
Ethan,
Many vintages of those switches have the same connector that was used on the Paso. If it looks the same, then it should fit. the mounting bolts are a bit different, but that can be overcome with a rattail file.
