MY 1992 907ie Rebuild was a tidy up now it's a full strip.
Finnpaso
year: 0
Re: MY 1992 907ie Rebuild was a tidy up now it's a full strip.
Post by Finnpaso »
JWilliam wrote:Jesus
I would say: Jesus "CHRIST SUPERSTAR" in this case.... :mrgreen: :mrgreen: :mrgreen:
907IE -91 red/metal grey
907IE -91 red
ducbertus
Post by ducbertus »
Hi Steve,
about the shock. if you heat up the aluminum parts with an electric paint stripper torch, the corrosion layer breaks as aluminium expands more than steel. use a plastic or copper (prefered) hammet to tap the bolt out. this avoids damaging something
Ducbertus
Jaffa
Post by Jaffa »
Hi Stiv,
the last photo appears to be of the lower radiator mounting bracket. I to had a broken one of these when i bought my beauty. They are a very light aluminium/alloy material. Fairly easy for a fabricator to either replace or weld, however, I also found an ... interesting replacement, which I wil take a photo of and post here later.
Good luck, I wll be following with interest as this time next year, I will be doing the same. In the mean time, I just bought an '84 750 Katana to get some practice on.
englishstiv wrote:Well the frame is now just a shell ready for sandblasting which I hope to do over the weekend, I have managed to find several other cracks on brackets???
I know from the damaged bodywork and previous owners knowledge/history of the bike that it has had a few slow road slides so I wanted to check the frame for any strange twists or other damage thank fully there is nothing and to be honest the bike rode straight and true in the brief time I had her on the road before this stripdown.
I have found somewhere for the engine brackets however the one welded on the frame has a stress crack which was probably due to the front bracket being damaged so this will require a supporting weld
Can anyone confirm for me that this is the correct shape of the front fairing/headlight frame this is shown from underneath and is on the right side as you sit on the bike, if it was straight the frame itself would be crooked so I assume this is correct? Just confirming folks
This has been another real headscratcher for me is the bolt threaded in here or loose? As if it is, then I will have to drill it out as it siezed solid the two bracket bolts were the same only I eventually persuaded them with brut force and heat to pop out - BUT NOT WITH THIS ONE
The starter motor bolt is badly corroded and I will have to grind this off and renew I will also sort out the earth adaption shown elswhere on this site while I am about it aswell.
I found one other bracket a bit twisted and cracked also, this looks like its made of an alloy metal?
There is more to come and lots of fun - wait till you see the state of my body panels that I am starting repair???
Jaffa
'91 907ie (RED)
'82 900 Mike Hailwood Replica
Volvo aware Motorcyclist
englishstiv
Post by englishstiv »
Well it's been a while but I finally started on the bodywork, Having known that the bike had been thrown down the road a few times with various previous owners and the last having been a bit of a slap and paint type of restorer I thought I might as well peel back the years of paint and start from afresh and boy did I get a surprise..................... :shock:
Having used a hot air gun I melted away up to 10 layers of primer, etch, filler and final coats of paint to find a multitude of repairs and damage...........so now the fun begins :lol: :lol:
amazing what a bit of bog and paint can hide - no wonder the bike leaned to to the left!!!
This is a slither of paint pretty thick ugh?
THE FUN CONTINUES .....the wheels are next to have their paint stripped...
DUCATI 907ie 1992
Ducati Streetfighter 955 V2
persempre907
Post by persempre907 »
englishstiv wrote:Having used a hot air gun
Don't the plastic fairings go melted with the hot air gun?
ducbertus
Post by ducbertus »
No they won't.
the material is GRP (Glass reinforced plastic or in this case polyester)
If you're using an electric paint stripper and behave gentle it's OK.
the paint starts to weaken up at about 100 degree Celsius, I believe.
the GRP takes a lot of heat more to get damaged.
I have also a set of battered 907 panels waiting for repair laying around. :cry:
Ducbertus
englishstiv
It depends on how hot you heat the surface, it does help that I am professionally trained at this as well, also theses panels are not exactly plastic as they are a fiberglass composite the side air deflector shell covers are plastic and these need a little more care. I also have the benefit that I am still not removing all the paint as at this white surface level there is still amazingly 5 coats of paint remaining!!! It peeled away that easily that it took just under four hours to complete this stage and will probably take that long to clean my garage floor :smoke:
DUCATI 907ie 1992
englishstiv
I have spent about 2 hours plus tonight trying to tease that bolt out of the rear shock fork hanger with heat (and lot's of it - electric and gas), and brute force and it's not budging so tomorrow I am buying a drill bit and drilling the bugger out what a pain this is being, I might just buy another hanger - are they the same as on the 750 and 906?
DUCATI 907ie 1992
you mean the linkage on the bottom of the swingarm where the shock is mounted, too ? That`s the same on all.
http://cgi.ebay.com/ebaymotors/87-92-Du ... ccessories
http://cgi.ebay.com/ebaymotors/DUCATI-P ... ccessories
englishstiv
:thumbup: IIIIII! thankyou
DUCATI 907ie 1992
injected
Post by injected »
I'd take it to someone with a hydraulic press before trying to drill it out....
blazing928
Post by blazing928 »
I am having my panels bead blasted to remove the old paint.
The finish is a bit like shark/dolphin skin in that it has a slight rough/dimpled finish.
Nigel
91 907IE - full restoration
MPL Slipper,Ceramic exhaust
Lambretta LI150 S3
87 928S4
englishstiv
I thought about that and was quoted £40.00 by a local machine shop :mad: They also implied they were concerned with it being a soft aluminum fork about causing it to buckle without good purchase/support, I have tried clamping it with the vice and using tubing to support it and pressing it that way myself it is rock solid even with heat, my other concern is any damage that I may cause to the lower pivot on the shock itself as that could be were it is seized, if I drill it may create some additional heat that will assist in releasing it, I thought about grinding between the spacers but none of my discs are fine enough. If I have to sacrifice the pivot arm then that will happen but only as a last resort.
DUCATI 907ie 1992
englishstiv
:lol: :lol: If I did that with these half the the panel would of probably disintegrated :,( :D
DUCATI 907ie 1992
guess I`d rather use paint stripper than bead blast fairing parts.
