Seat Fix
Duc906
Seat Fix
Post by Duc906 »
For those that are having trouble with their seat moving forward and releasing from the latch at the back while they are riding,I have a fix.All I did was to cut a piece of fuel hose down the side and slip it over the back of the fuel tank mount,add a bit of silicon to keep it in place,simple.If one piece is not enough just add another over the top.
Re: Seat Fix
Now thats the sort of repair I like to see, cheap , effective and not unsightly. Pity you didnt use #8 wire to hold it on but there you go . :P . So when did you move from NZ :lol: .If the rest of that bike is as clean and tidy as the bits I can see it will be a nice bike
regards
hamish
duckboy
Re: Seat Fix
Post by duckboy »
Hiya Ken
this incident first happened to me, whilst on a ride... a long way from home. unfortunately when the seat swung off, the rubber bumps under the seat tore the wires out of the battery, and killed all electrics. (so there was a bodgey roadside repair to the wiring, and half a roll of duct tape used to secure the seat.)
annywaay... here is how I solved the problem.
It looks a bit rough, but it does the job.
cheers
Brett
persempre907
Re: Seat Fix
Post by persempre907 »
duckboy wrote:this incident first happened to me, whilst on a ride... a long way from home. unfortunately when the seat swung off, the rubber bumps under the seat tore the wires out of the battery, and killed all electrics.
:shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
I hope you have'nt had any health's damage from such accident.
Duc906
Re: Seat Fix
Post by Duc906 »
Hey Duckboy
Good to here from you. :beer: Hopefully your rear end was still not in the seat when it hit the ground. Your fix is a bit less agricultural than mine,good work. :thumbup:
duckboy
Re: Seat Fix
Post by duckboy »
Luckily the seat never actually hit the ground, I was able to trap it between my leg, and the sidecover as it was half hanging off. It happended after a large bump in the road which lifted me out of the seat (actually the seat came with me), I think it snapped the wires (to the battery) as I was trying to re-position it without stopping.
:wacko:
Brett
hardo
year: 0
Re: Seat Fix
Post by hardo »
Dear all
I have the same problem and just the fix provided by duc 906.
It helped for quite a while but the problem is here again. The fixing at the end of the seat (rear end of the the paso) pops of.
Any suggestions for a quick fix?
Thank you, Hardo
stigonpaso
Re: Seat Fix
Post by stigonpaso »
I'm planing to go the Duckboy route by putting a thicker plate on the end of the seat.
Re: Seat Fix
Duc906 wrote: Your fix is a bit less agricultural than mine,good work. :thumbup:
Either of those repairs would make any Kiwi beam with pride :) . Im wondering ( without racing out to look at my bike ) if the seat is being properly supported ( rubber buffers ) , if not it maybe that the seat base is bowing under rider( and pillion ) weight making the seat a bit shorter and ....... :o
JWilliam
Re: Seat Fix
Post by JWilliam »
Not heard of this one. I got around this by using a Diopa single seat unit for the last few years apparently. It must be the plastic under tray deforming... tricky.
lane1feathers
Re: Seat Fix
Post by lane1feathers »
I used the now obsolete muffler retaining bolt, drilled out the hole a bit, and glued it in with some REAL GOOD glue. (Obsolete as I have after market mufflers)
Works real good
This is more of a trial to see if I can successfully upload a pic to my thread, so bear with me!
Lane
89 Dark Blue 906 Paso
lane1feathers
Re: Seat Fix
....damn..... :truck:
Lane
Re: Seat Fix
fixed
lane1feathers
Re: Seat Fix
Awesome, it worked
Now I can put it up here instead of just a link
Thanks G.
PS feel free to delete these last messages :thumbup:
