Belts and valve kit???
Hi, does anyone know where I can get belts and a kit for the valves????? Thanks
Re: Belts and valve kit???
Belts are easy to get from many sources. What do you mean by valve kit?
bevel heaven,california cycle works, desmo times,and heaven forbid the dealer
silly newbie
silly newbie
Shim kit: http://www.emsduc.com/products.html
- Finnpaso
- year: 0
valve kit...hahahaha.... I QUESS, he means valve clearance adjusting pieces (like Tamburinfan wrote: "shims") for closer and opening.... Btw, valve clearance adjustments needs also TOOLS to make it... and "knowing how to do it"...
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
- jcslocum
Ask the magic list and you shall have the information.....Finnpaso wrote:valve kit...hahahaha.... I QUESS, he means valve clearance adjusting pieces (like Tamburinfan wrote: "shims") for closer and opening.... Btw, valve clearance adjustments needs also TOOLS to make it... and "knowing how to do it"...
http://ducatitoolrental.com/index-3.html
Thanks for the condescending comments, I thought this was a forum to help others!
- persempre907
They lack only the shims...jcslocum wrote:Ask the magic list and you shall have the information.....
No matter, very nice idea
- jcslocum
persempre907 wrote:They lack only the shims...jcslocum wrote:Ask the magic list and you shall have the information.....
No matter, very nice idea![]()
Scroll down....
http://ducatitoolrental.com/index-6.html
- jcslocum
Vince, there are lots of folks here with many may odd personalities. You gotta have a little bit of a thick skin to post to forums! We are a good natured bunch from around the world and are just funning you.Vince wrote:Hi,
We did help, and there is a place to rent the tools and shims.
Thank you to all that responded, I now have a good idea on how to proceed!
Regards, Vince
Regards, Vince
- persempre907
You can really rent everything... very, very nicejcslocum wrote:persempre907 wrote:They lack only the shims...jcslocum wrote:Ask the magic list and you shall have the information.....
Scroll down....
Hi Vince
If your looking for info on valve jobs try ducatitech.com , they have a 2 part video that is well worth a look
